sloppy cuts on roll downs
Guest crewdog10
Guest crewdog10
I tinted a 91' Honda Accord yesterday and it came out pretty well. But I always have problems with the roll down windows and was wondering if I am going about this the right way.
After I lay the tint on the window, I will trim it leaving roughly a half inch in all directions. Then I cut the rear starting from the top going down. When I insert my knife, its usually not precise because the film is partially lifted off the glass, and when I go down I tend to cut slightly wavey. If I start from the middle I can get the line right, but when I go up or down, I still have problems where the film bunches at the corners because of the overlap. The same problem applies to the front cuts as well. I am somewhat of a perfectionist and this is really p1ss1ng me off.
Other than this problem everything went well. I laid the best rear window that I have ever done on this car using the reverse rolling technique, I am really proud of it. But damn these roll downs. :thumb
Guest crewdog10
Yeah, I think that is what I'm going to do next time. I'll cut approximately a six to 8 inch line in the middle and use a straight line ruler to finish the cut. I guess it's just practice, practice, practice. Thanks tintdude.
    2. 7
    6. 11
    7. 11
