2016 Impala
MaxxedOutTint
I did the wedges at first, but after half a roll of paper towels and a million squeegees, the black rubber part was spitting dirt and grime. It almost seemed like someone had used goo gone on the rubber, it was super soft an if you swiped your finger on it itd rub off on your finger
I cut two wedges out of a old blue max and just slide the film behind it
Easy pezzy same for Darts,Challengers and Chargers
After messing up my neck a few times trying to wrap my arm around to unbolt the light and see at the same time, I started doing this. Some of em seem like the rubber doesn't sit tight on the glass after putting it back.
And not regular thread,  fine machine thread takes forever.  pulled a few then started cutting around.  Called a Skew driver, right angle attachment for cordless drills.  regular bits and sockets with adapter was a must have for the 12 volters.  If I can find another, will start pulling again.  I used to carry my 10.8 volt makita's and stopped years back.  Now with new vehicles requiring more disassembly reconsidering adding it back into my tool box.  Yes 10.8 volt  tiny little drill and impact goes where the big ones don't.
    2. 7
    6. 11
    7. 11
