2004 Toyota Solara
Guest expertint
Guest expertint
Not bad, had to take two panels off each side and remove the panel..well worth the effort rather than try to get down there..Needs vinyl also..
Guest TINTGUY78
if you use a bigfoot (long triangular shaped tool with a handle) you should have no problem getting behind the third brake light. why does everybody take the rear deck out? I work at a toyota dealership and use a tintek to cut out the brake light and have not had to take the deck out on one car at all. time is money and when you can knock out a car in 30 minutes without taking the rear deck out then I say why not.
    2. 7
    6. 11
    7. 11
