2017 Lincoln MKZ
jlmontec
Kind of like a Ford Taurus but the back tray is smashed on the glass for the bottom !/2 inch. :olfa  :redturbo  :film  :facepalm2
Beware- cut perfect or remove the rear dash.
(Not too many of these out there luckily.)
Did you mean they are like a fusion and not a taurus? I haven't done a 2017 but I've done a 2016 and it's similar to the Ford Fusion. Carpet right up on the glass especially if it's a hybrid.
Whether it's a fusion or mkz I pull the rear deck. Much less stressful.
 i just cut the bottom of the pattern really smooth and exact. reverse roll the bg piece out nice and flat without sqeegeeing all the way across the window bottom leaving a couple inches above the fuzz, then slide the film down and use my fingers to push it down into the bottom, just enough to cover matrix border. you can even use a crows foot to pry it a little. i have evensometimes hit the fuzz with a little heat to make the fibers cringe or basically melt tighter just dont do it if someones watching thats gonna be a pest. it doesnt really hurt anything if you do it fast.
