The Upgrade Thread
  • Replies 137
So, on the computer, if you hover over the title of the thread; you will get a pop-up window that shows the first post in the thread.  You can switch that to the latest post at the top of that pop up window, so you can see the last thing someone posted. :thumb
Also, I see we get notification when someone give you a reputation point now. :chin
1 hour ago, DynamicAppearance said:
Not sure what happened, but I had a sword before the switch over.  :dmc
The system is recounting and rebuilding several systems. Once it's done your post count and member levels should be corrected. :)
The signatures have a ton of spaces after everything.... The forum software seems to have put a <p> for every line... not sure why it did that.
I manually edited mine and removed them and used <br> (line break) to make it look how it was before.
Not sure if this is something that can be changed automagically or what.
I also noticed when, for example, posting this reply everything is double spaced. Which if you click on the 'source' button - again, it's adding a <p> after each line.
Just something I noticed... not a complaint - more an observation. :)
    2. 7
    6. 11
    7. 11
