egetorp Posted April 12, 2017 Report Share Posted April 12, 2017 I've done 2 of these and had trouble with both. How do you get the tint behind the side seals and not kink the crap outta the tint? I don't remove door panels. Link to comment Share on other sites More sharing options...
highplains Posted April 13, 2017 Report Share Posted April 13, 2017 7 hours ago, egetorp said: I don't remove door panels. That's your problem, I always pull the panels on that one. The panel pull relatively easy, there is a screw behind the handle and two behind a plate under the grab handle if I remember correctly, once those are removed the panel can be popped off. I don't remember at the moment if the seal is attached to the panel or if you can then pull it out, I think it's separate haven't done one for a couple of months. Anyway with the panel removed they are really easy to tint. Link to comment Share on other sites More sharing options...
egetorp Posted April 13, 2017 Author Report Share Posted April 13, 2017 Ok cool. Thanks for the info! I wish I could've tried to pull out the rubber that goes up the sides but the guy was there watching me. Link to comment Share on other sites More sharing options...
