Advise needed on Coil Spring size...
Hello, I'm working on a fairly complicated piece, at least the most complicated I've ever tried before. It's a tufted and channel backed settee. I'm working on replacing the coil springs in the seat, though I'm not sure what size to use. The back rail is 2" deep. The front rail on the other hand is 4" on the sides and 5" in the center, so the depth throughout the seat is different at all points. I am using mostly 5" coil springs, but used a few 8" coil springs in the front center where it is the deepest. Is this right? Can I get by doing this? Or should I use 8" springs through out?
