2017 Hyundai Genesis G90
Midtown Houston
Here are the instructions for removing the sweep from the new G90.
Front Doors:  remove 1 screw behide the handle and 1 screw from the armrest.  Pop off door panel toward the lower front of the panel. Remove your sweep and done.
Back Doors:  took us some time to figure this one out.  Remove screws like you would the front door. Pop off door panel and remove top cover. Remove 6 black screw to release auto window screen (what ever it is called). I put blue tape to show you guy where the screw are located. Pull the auto screen away from door (it is a little tight due to the sweep but it will release). You have to do this to remove the sweep due to it being one piece and stretching to the end of the quarter glass.
Edited by Midtown Houston
1 hour ago, Tintbits said:
I do these all the time and have yet to pull a panel. Easy car, why make it harder?
Because that's his preferred method. You have yours and he had his neither is wrong if the customer is happy with the outcome.
