Sign in to follow this
diaconufernando
Old Mercedes E Klass help
you need to remove this glass in order to tint it ?  Is posible to tint this glass completely without removing it?
I use a Lil chizzler or two. Put them in the back part of the gasket when I pull the car in by the time I'm done installing everything else the gasket is open enough to get my ez-reach in to push water out. I also use a little extra slip to get it in and look good.
Or you can cut a little off the back side gasket.
Share this post
Link to post
On this model trim the rubbers. If you do a light tint then you might be able to see the trim. Make sure you do it with a sharp blade and on one pass don’t hack it. The plastic at the rear of the door pops off this will allow the rubber a few extra mm of slack. It doesn’t pop off completely just a little bit. Squeegee with an ezreach
Share this post
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
