2017 Toyota Prius
Midtown Houston
Front door panel must be removed to do window film install.  Since we like removing the sweep on most of our install, we remove the rear door panel too.
1. pop arm rest 1st with push stick (1 Phillip screw there)
2. pop window roll switch panel next (1 Phillip screw there)
3. Pop cover behide door handle (1 Phillip screw there)
4. and that all folk
Easy car and film and vinyl design cut perfect for this model.
48 minutes ago, coast2coasttinting said:
Try using mini bungee cords to hang your door panels.  Works great I promise. Bravo on going above and beyond to do good work.  👍
We always have packing blanket under every door but the shop got a little water from Hurricane Harvey....Our first open for tint in 6 days and all the blanket are air drying. Great idea...will be buying it on our next trip to Home Depot.
We always have packing blanket under every door but the shop got a little water from Hurricane Harvey....Our first day open for tint in 6 days and all the blanket are air drying. Great idea...will be buying it on our next trip to Home Depot.
