Small fingers
I just tinted a couple windows this morning and on one window, the bottom would not want to lay down, after hearing it up, it finally layed down. So on the other window, I didn't use as much soap in the solution which helped a lot more but I still had a couple little fingers, both sets of fingers were right below the bottom seal. My question is will these small vertical fingers go away after a few days?
What kind of car was it?
What's likely happening is the water is pooling up on the bottom seal and causing the film to not want to lay down. Squeegee pattern has a lot to do with it as well.
Edited by jh812
ram 1500 and many other vehicles have the inner sweep higher then the outer sweep,  I refer to this as a "negative offset".   If the inner sweep were lower then the outer,  you would have never seen those fingers and it would have peeled eventually.
So what if we snapped the top or shrank the top?  if little fingers popped up on the top,  easy to see and heat down.  No reason to pull door panels or sweeps then.
process with heat gun or torch on my youtube channel
saw that video, good stuff shady
    2. 4
    3. 4
    4. 4
    5. 4
    6. 1
      Beginner Tinter
    7. 0
      SIGNALS DEFENSE - EXPERIENCED WINDOW TINTERS NEEDED - COMMERCIAL
    8. 5
