Small fingers
6 minutes ago, Jkatfelix said:
i use the 5 gallon sprayer all the water pools up at the rubbers instead of falling thru.
The gasket wizard/shields will let the water go thru but seals removed is easyier to slide the film in
Edited by DOOTINT
Maybe try a less soapy bottle for bottom half are you using tint slime or dishsoaps dishsoaps makes alot of suds and messes stuff up on sticking if you have way too much soap try slime orange one or baby shampoo get your mix perfect just enough slip so it will dry watch shady and Ralph van pent they soak it up or push it out side ways and gasket wizards are killer they keep seals dry...
9 hours ago, IPATinting said:
I just tinted a couple windows this morning and on one window, the bottom would not want to lay down, after hearing it up, it finally layed down. So on the other window, I didn't use as much soap in the solution which helped a lot more but I still had a couple little fingers, both sets of fingers were right below the bottom seal. My question is will these small vertical fingers go away after a few days?
What are you using for solution???
      Contravision
    2. 29
    4. 3
    6. 4
    7. 3
    8. 4
    9. 3
      New tint. Not happy
    10. 3
