Mr paladin Posted January 23, 2018 Report Share Posted January 23, 2018 lately It has been cutting jagged edges usually just on a curved cut usually the top not on straight edges I have a new blade,new blade holder and new strip.any ideas ? Link to comment Share on other sites More sharing options...
highplains Posted January 24, 2018 Report Share Posted January 24, 2018 Is it cutting that portion on a push or a pull? Link to comment Share on other sites More sharing options...
Mr paladin Posted January 24, 2018 Author Report Share Posted January 24, 2018 On pull. Link to comment Share on other sites More sharing options...
highplains Posted January 24, 2018 Report Share Posted January 24, 2018 It's possible that it's in the cut file, I've come across a few like that. I've also seen that when it cuts on a push and the material starts to try and bunch up and it distorts the cut. Link to comment Share on other sites More sharing options...
Tintmaster08 Posted January 25, 2018 Report Share Posted January 25, 2018 Replace your cut strip Link to comment Share on other sites More sharing options...
redneckj Posted January 26, 2018 Report Share Posted January 26, 2018 Is the cutter head tight on the main frame that runs left to right? You can can easily tell if it's a template problem if it cuts the same pattern the exact same way. Link to comment Share on other sites More sharing options...
Guest Will check it out Posted January 28, 2018 Report Share Posted January 28, 2018 On 1/25/2018 at 11:04 PM, redneckj said: Is the cutter head tight on the main frame that runs left to right? You can can easily tell if it's a template problem if it cuts the same pattern the exact same way. I will check it out Link to comment Share on other sites More sharing options...
blade Posted January 28, 2018 Report Share Posted January 28, 2018 we had issues like this and a driver and cable update took care of it.....it was a communication issue. you might try that Mr. P. might work might not.....just a suggestion. Link to comment Share on other sites More sharing options...
Mr paladin Posted February 3, 2018 Author Report Share Posted February 3, 2018 On 1/28/2018 at 5:03 PM, blade said: we had issues like this and a driver and cable update took care of it.....it was a communication issue. you might try that Mr. P. might work might not.....just a suggestion. Thanks blade will check it out :thumb On 1/25/2018 at 11:04 PM, redneckj said: Is the cutter head tight on the main frame that runs left to right? You can can easily tell if it's a template problem if it cuts the same pattern the exact same way. I will check it out Link to comment Share on other sites More sharing options...
