2018 Acura RLX
GlassWithClass
New hybrid. Front doors are a breeze one screw under rubber in arm rest, pops right off. Back doors same deal to get the panel off. However the sweep is attached to a privacy screen, you need to remove the screen. Its attached to the quarter window screen also. Pop the front cover off the quarter window screen its three red clips. There are two silver screws behind that you need to remove. Once the panel is pulled there are four more silver screws along the bottom of the screen that need to be removed, then the whole thing comes off as one unit. After that its just another Acura. BG is flat, has a moulded third brake light, buy easy to get your dozzer or whatever you use behind it. Did this one in 20%.
