Air bubbles
Did a dodge ram front two roll ups
Next day customer call say theres bubbles so he him come in and re did it . Today got the same call bout air bubbles . What could b causing this and yes me sure the 2nd time I gave the window several good passes with the blue max
If you are getting air bubbles, you are not wetting the entire window and piece of fil and causing your squeege to run over dry spots. You need to install and close the door and look at the window from the outside and you will see
sounds to me like film is blistering after install.  i tell all my customers that blistering on the inside may be present during the drying phase which is normal.  give it a week to fully cure and if problem still persist, give me a call immediately because tint and labor is under warranty.
