Door panels marks
that doesn't dry out, the water got through the stitching and the CARDBOARD absorbed and expanded, it wont change back to its original form. I always tape and cover the stitched door panels from bmw, water just makes its way in.
YES bmw does make the door panels out of cheap recycled cardboard material.
8 hours ago, DynamicATL said:
Looks like water damage...did you happen to use Tape N Drape or similar across that section?  Thinking if so that area got wet were the tape was placed.
I did not cover it with tape or anything but lesson learned....cost 300 to replace door panel
@Jkatfelix
BMW’s are the worst, followed by Porsche. I’ve been there, it really doesn’t take much to seep in. I use the narrow roll of blue tape and plastic from Home Depo, in the paint section. If I need to top load a window, I’ll put a layer of that green tape to seal it down. If it’s getting a lot of water that blue stuff will leak or even fall off.
