New Ford Explorer back door wings
12
12
12
Geoshield vs Maxpro
I start those at $750 and go up. Best advice is no cutting on the glass and white scrubbie only, no cleaning blades. That glass is super soft. You may want to use a film liner to make a template to cut your patterns.
