Use Sprayway glass cleaner for last squeegee before install
I have been using Sprayway glass cleaner for the last squeegee before install before I was using Dawn and it was leaving streaks and I was getting contamination let me know if this helps anyone it's been working good I know a few people on here use it just wanted to share with you and use distilled water always with whatever you're using
Edited by quality tintz
I use it before razoring window and final sqeegee. I was amazed how well it breaks down adhesive for removal. I cant believe nobody ever mentioned it. I mixed up some dawn and alcohol a couple weeks ago.  Works ok, but the sprayway has better coverage and no mixing stuff.
7 hours ago, quality tintz said:
Does the water flush better ???
Yes, much much better.  Spray some sprayway glass cleaner on your peel board.  throw some black  pepper in it.  Use slip solution to wash it down the glass,  Then do the same thing with straight water.  you will see the difference.
Quote
10 hours ago, CaliTINT said:
Interesting. Never heard of this. I only use sprayaway for scrubbing the back window and cleaning seals and surrounding areas on the side windows.
I use 409 on all that, but it's just my preference. I agree with @redneckj about using the water alone, no soap on the market will tell you to rinse with more soap, be it dish liquid or shampoo, the soap catches the dirt and is to be wiped or rinsed away with water. So he made a great point and i'm going to start doing what he said.
    2. 3
    3. 3
    4. 3
    5. 1
      Beginner Tinter
    6. 0
      SIGNALS DEFENSE - EXPERIENCED WINDOW TINTERS NEEDED - COMMERCIAL
    7. 5
    8. 5
