Yeah that’s a very fair point to a degree I’m probably overthinking it. I don’t see really significant glare reduction until you get into much darker tint. Like you I think visibility for me is more important living in the country. I’ll probably see what the specs list the differences between 70% and 80% and then double check with the tinter as to what they recommend. Likely will end up with 70% with a strip along the top. Air80 seems to be much more popular, not sure if it’s due to performance or the difference in cost being so much more for the stratos.
thank you
Hey guys - so I work for a vinyl graphics company that is adding window tinting to their repertoire and I had a question about your guys' ideal process. I have my plotter set up and my window tinting software ready to go, but I am completely ignorant about the way that tint installers prefer that things be cut. Currently, I will plot/weed the tint and cut the backing away as much as I dare before handing it over to the installer. I was thinking that the installer would prefer the tint to be cut to shape which I believe I can achieve with the perf cut on my plotter. Is that the typical process or should I not be worried so much about it being cut to exact shape?
Im in TX, plenty of of what you mentioned. While I do sit higher in an SUV, glare reduction is not improved much at all with what I have. My 80% is almost clear, not dark at all. With all tint, it adds a bit of reflectivity from the outside, which I notice makes it slightly harder to see from the outside looking in, in the form of a glare not darkness. At the end of the day, it's not permanent, it's only money!
Hello. My name is Adrian i have good experience with paint protection film and i just moved to California, Irvine, i'm open to travel one hour away for the right job. You can contact me at 5717330693
The answer is to not heat that area too much so that you leave some slack in the film for when you get it to the inside.
Also cut your pattern a little large so that you can trim a thread off the edges after shrinking to not have a furled edge.
After you do a few of those you'll figure out how much to leave/trim to not have any light gaps. Also I'll leave a hardcard wrapped in a microfiber in the bottom overnight to collect water and keep pressure on the film while it dries.
Sometimes you can take the top rail off the glass if the jackwagon boat builder didn't put too much pressure on the glass package when it was installed. If you pull the rail off of a tight package it's a pita to get back on, looking like it could crack the whole time.
Congrats on getting it done. I've seen plenty that couldn't, which is why I price them like I do.
