New 3 series 2020?
no ma'am
Update to the update.... 2 screws on every panel, 1 behind handle 1 below armrest. Pull seal first tint window then pull screws pop panel off to put seal back in
Thank you very much. You saved me from a heart attack
For the rear quarters there is room to tuck at the bottom so I line up the straight vertical with the exact edge of tint, the top angle I cut as exact as I can, the bottom angle I leave long and cut on the inside.
Trick for the rear brake light is unclip the headliner, 1 clip on each side beside brake light, the  unclip the brake light by pulling  down and you can reach inside to squeeze the black tabs together with your fingers to remove
