Guest LoneStar Posted October 25, 2019 Report Share Posted October 25, 2019 Today was the first 2019 Chevy truck that I've done and I found the bottom gasket to be very tight. Anybody else have this issue or had a good work around Link to comment
ErieTint Posted October 26, 2019 Report Share Posted October 26, 2019 I am a bottom loader so I normally either pop tops or remove panels so I can remove bottom sweeps. That being said, these bottoms didn't seem overly tight if I were to top load them. Have only done fronts on the new body style, cannot comment on rears. TintDude 1 Link to comment
highplains Posted October 26, 2019 Report Share Posted October 26, 2019 Fronts pull the panels and remove the sweep. Rears you can pop the top and remove the sweep. It makes life a hell of a lot easier on these trucks. In the makes and models section there's a write up with pictures. TintDude 1 Link to comment
CnCCustoms Posted October 28, 2019 Report Share Posted October 28, 2019 We snatch the panels on em. The time it takes to fight with those tight sweeps is time spent removing and reinstalling the panel. And much cleaner job without the headache Link to comment
Guest Pitu Posted October 29, 2019 Report Share Posted October 29, 2019 Remove panel. Cleaner installation.no fighting with crease Link to comment
