Help me, how do I tint this back glass QX4
Guest Bbpv6
The best way to do that particular piece of glass is to remove it and tint it on the bench with all the hinges, strut mounts, latch, etc. removed. It's pretty easy and straightforward to remove, if you need help figuring out the lift struts look up lift strut replacement for that vehicle on YouTube, it's a lot easier to understand what you need to do when you can see vs reading it. From 97-04 the Infiniti Qx4, Nissan Pathfinder, and Honda Passport are basically the same vehicle.
I'd hit the defroster lines with 0000 steel wool, you'll see them start to shine up as it cleans all the oxidation off them, just be careful not to go too far and don't use any steel wool other than 0000 or you'll scratch the glass. The tint should lay right down on them, having it on the bench will make it easier to get your film positioned before squeegeeing it out.
    2. 7
    6. 11
    7. 11
