2020 porsche911 headlights
just a heads up , the new porsche headlights are removable.
the car has a switch where you can lift the front about 2more inches for access.
the inner liner needs to be removed (11 screws- 4 at the bottom , 7 in the wheel area ) , or dropped to have access for the 2 bolts that holds the headlight. no bumper removal needed.
after all the bolts area removed , you will need help when pulling the headlight, one person push from inside and second holds it in the front. also masking tape should be used around the headlight before removal.
the inside  front bottom of the headlight has a pin that slides into a small track. (in pic marked with red)
Edited by PRatx
23 hours ago, Speed said:
I just tuck the film behind them using a flat blue card
the pic you posted is the older light and the flat card works  , not the NEW models.
upper lights has a mesh under the lens. did you try the flat card with new models?
headlight is fully  integrated in the fender, and the fender is wider, will need more stretch to wrap the fender.
Yes I have and yes it works with the 992.  I've done dozens already and it is a bit tricky on the outboard side because the headlight isn't as tight against the metal there.  Only had a pic of the old one so I posted that since it was the same hard card I use.  I just start near the bottom and "saw" my way around till its all tucked.
      Contravision
    2. 29
    4. 3
    6. 4
    7. 3
    8. 4
    9. 3
      New tint. Not happy
    10. 3
