Chevy panel streaks
On 5/28/2020 at 9:32 AM, Trent said:
Currently tinting a 14 High country Silverado. I’m covering the panels but some water got behind my plastic. What is the best dressing/solution for helping with the streaks?
I use maguire's quick interior cleaner, it's worked on every one I've ever had streak. Just mist it on a microfiber cloth and rub it in across the streaks.
Detailers spray polyethylene on the doors to make them shiny at car washes and dealerships . So when it gets wet it looks like that . But a good cleaner will take the polyeurothane off . If you want it back on just buy armor all or something like it .
If it is just streaking but not peeling then it will dry. You can heat it up to dry it if you feel the need.
If peeling then scrub it with a scrub pad as in the post shared.
If its just streaks, dont rub them lightly, pat dry and use low heat to dry. Now for the secret ..... Peanut oil or popcorn oil . lightly rub on a thin coat and your good to go.  The peeling seems to only occur when wet and rubbed hard with a cloth and i dont think you can fix that.
