MR ANDERSON Posted July 21, 2020 Report Share Posted July 21, 2020 our plotter is having issues and i think it's caused by the strip wearing out. it will cut through in some areas and not even score the film in others. ive ordered a new strip and blade but im here to see if yall have any temporary solutions or ideas if it could be something else wrong with the machine. Link to comment
highplains Posted July 22, 2020 Report Share Posted July 22, 2020 Sounds like you're on the right track, replace the strip and blade and go from there. Don't forget to dial back the cutting pressure with the new blade or you'll cut through the film and liner and score your fresh cutting strip. Link to comment
MR ANDERSON Posted July 22, 2020 Author Report Share Posted July 22, 2020 thanks, any advise for getting it calibrated properly. this blade and strip have lasted a year with every day use. im not sure if that's good or not. Link to comment
highplains Posted July 23, 2020 Report Share Posted July 23, 2020 I've got an FC series plotter so I'm not sure if the adjustments are going to correlate 1:1 but with my most recent blade & strip replacement I dialed the cutting pressure back by 6 steps, so it was at 21 before now it's at 15. You'll need to play with it and fine tune it for your individual film and plotter, it's better to err on the side of caution and dial it too far back first and step it back up as needed. Link to comment
