Lambkilla Posted September 13, 2020 Report Share Posted September 13, 2020 (edited) I got my E90 tinted 3 days ago and the installer did fine except they had popped a single bubble on the rear glass. Will this go away as it cures, should I accept the fact it’s there or have them redo the tint. for reference it got ceramic tint (not sure which brand) and has sat in the sun for 3 days now. *edit: measured the bubble .4cm Edited September 13, 2020 by Lambkilla Link to comment
Lambkilla Posted September 13, 2020 Author Report Share Posted September 13, 2020 Paid $399 btw.. Link to comment
highplains Posted September 15, 2020 Report Share Posted September 15, 2020 It's not going to go away on it's own. As far as living with it or getting it redone that's something you'll need to decide for yourself. If it were me and that's the only defect then I'd probably give them the opportunity to touch it up, maybe make it less noticeable and then live with it. There's always a risk of getting some type of contamination, they're never perfect. Now if there are other defects in that window that would potentially sway me the other direction. Link to comment
pbalentine Posted September 15, 2020 Report Share Posted September 15, 2020 I would just leave it. If you have it removed then you might have adhesive left over, which would look worse. I rarely will redo a back window I certain models. Link to comment
Lambkilla Posted September 16, 2020 Author Report Share Posted September 16, 2020 On 9/14/2020 at 8:26 PM, highplains said: It's not going to go away on it's own. As far as living with it or getting it redone that's something you'll need to decide for yourself. If it were me and that's the only defect then I'd probably give them the opportunity to touch it up, maybe make it less noticeable and then live with it. There's always a risk of getting some type of contamination, they're never perfect. Now if there are other defects in that window that would potentially sway me the other direction. On 9/15/2020 at 11:11 AM, pbalentine said: I would just leave it. If you have it removed then you might have adhesive left over, which would look worse. I rarely will redo a back window I certain models. Thank you for the replies, I decided to just chill out and accept that its there. Link to comment
drtint Posted September 17, 2020 Report Share Posted September 17, 2020 Sure it doesn’t look appealing right now, but as others have mentioned, leave it, let it dry, take your fingernail at that point and push towards the small fiber and be done with it. if you have them redo it, you may have three elsewhere. looks good from here. Cheers Link to comment
no ma'am Posted September 18, 2020 Report Share Posted September 18, 2020 Nobody understands a tinter except another tinter. (Think it was @TintDude) we wish we were perfect but have to accept that’ll never happen ( @no ma'am)there’s my quote! Being ocd and a tinter takes years off your life fast! Link to comment
