Mason Posted September 29, 2020 Report Share Posted September 29, 2020 Car : 2004 Pickup Car Scrubbed the rear window as clean as possible - 4 days later this is the result still Link to comment
Booms Posted September 29, 2020 Report Share Posted September 29, 2020 You need a compressor with a good air gun. Hose the window down with water, and then blow all the junk out of that rubber gasket. Otherwise you will never get it clean. You're welcome. Link to comment
CaptainSpod Posted September 29, 2020 Report Share Posted September 29, 2020 A major demon in the trade, the more years you add onto the vehicle the harder the job can be to get a clean install. Especially on an older truck. I found after cleaning the back window to not spray it again with water/solution and just leave it dry, then only spray the film piece and then bring it in that way. TNTLady 1 Link to comment
civicrice Posted September 29, 2020 Report Share Posted September 29, 2020 these are the vehicles that separate the pros from the noobs. even as a pro these are challenging. i like to cut out a slither and nylon brush the seal. after that i steam blast it with a steamer. then i lay a thin layer of elmers glue. like captain spod said only wet the film and reverse roll it on. Link to comment
jconnors Posted September 29, 2020 Report Share Posted September 29, 2020 9 hours ago, civicrice said: these are the vehicles that separate the pros from the noobs. even as a pro these are challenging. i like to cut out a slither and nylon brush the seal. after that i steam blast it with a steamer. then i lay a thin layer of elmers glue. like captain spod said only wet the film and reverse roll it on. or just reject it 😲 don't need any challenges anymore! lol florida tinter 1 Link to comment
no ma'am Posted September 30, 2020 Report Share Posted September 30, 2020 Wtf car/truck is this? Link to comment
Mason Posted September 30, 2020 Author Report Share Posted September 30, 2020 It's a Toyota Hilux. Thanks for the tip guys. I am going to give it another week to cure to see how it goes before making any further adjustments. Link to comment
deadjame5 Posted September 30, 2020 Report Share Posted September 30, 2020 11 hours ago, Mason said: It's a Toyota Hilux. Thanks for the tip guys. I am going to give it another week to cure to see how it goes before making any further adjustments. Thats not going to cure out lol CaptainSpod 1 Link to comment
CaptainSpod Posted October 9, 2020 Report Share Posted October 9, 2020 On 9/30/2020 at 11:58 AM, deadjame5 said: Thats not going to cure out lol It definitely will not cure out. That is contamination behind the film that will remain there until you redo it. TNTLady 1 Link to comment
