From wich company can I order ? š¢
Yeah thatās a very fair point to a degree Iām probably overthinking it. I donāt see really significant glare reduction until you get into much darker tint. Like you I think visibility for me is more important living in the country. Iāll probably see what the specs list the differences between 70% and 80% and then double check with the tinter as to what they recommend. Likely will end up with 70% with a strip along the top. Air80 seems to be much more popular, not sure if itās due to performance or the difference in cost being so much more for the stratos. thank you -
