Wanting to learn flat glass
Hi all,
I am very eager to begin learning to flat glass. I am based in Melbourne and have been on YouTube and these forums the last month learning as much as I can, I intend on buying a roll of film and practicing by tinting my entire house.
I have a few questions.
Which manufacturer of film do you recommend for residential jobs?
Do you guys tint over the safety symbols they have on glass to prevent people walking into the glass, or do you just scrape them off during preparation?
I can find plenty of videos about preventing contamination under the film, but surely there will be an event where there is contamination between the glass and film, what would you do in this situation?
Thank you guys.
Learn about film to glass charts, solar properties of film, solar absorption particular, and thermal stress.
I don't generally tint over any decals.  Contamination is going to exist. How much will depend on the age of the glass and frames as well as the type of materials.  You have to find an acceptable tolerance for quality for yourself and the customer.
If it is too much contamination then you pull it off and go again!
Thanks so much for the response Ryker, over the past few days I have been looking into this information.
One question i have is how do you determine the type of glass and thickness of glass that is installed at a job? I have found some thickness gauges online which you hold against the window and gauge it via the reflection? Or do you google search the decals and stamped numbers on the glass pane instead?
I personally don't worry about this much. Most are either single pane older windows or sinker pane insulated glass. While a low-e can effect the film choice I have not had any issues in 22 years. If its double pane I may try to stay a a general under a 50% Total Solar Absorbtion.
If you find a triple pane you probably won't get a manufacturer to cover it no matter what.
You can hold a light or lighter up to the window to find the number of panes and also often see a low-e coating.
      Contravision
    3. 29
    6. 3
    8. 3
    9. 4
