All2Epic Posted January 27, 2021 Report Share Posted January 27, 2021 I’ve been tinting for quite some time now. And I’ve gotten very good at shrinking the film to the back glass. However, I keep running into the problem of having fingers in my tint once I install the film. Most the time I hit them down with the heat gun, which takes forever. Yesterday I tinted The back window of a civic. It shrunk perfectly to the glass. To my dismay, there was a giant finger in the lower left corner with a few others here and there. Even the heat gun could not take care of the problem. I haven’t seen anybody else with this problem. Is there something I’m doing wrong? Perhaps not enough soap? Maybe not enough water? Perhaps my squeegee pattern is flawed?? I’m doing the [+] pattern. Im at a loss. Has anyone experienced this? Link to comment Share on other sites More sharing options...
smookee408@yahoo.com Posted January 27, 2021 Report Share Posted January 27, 2021 Two possibilities. Its not shrunk enough. Once you’re done lift the film again and do a final shrink down. Two its the way you squeegee and you’re creating the fingers. Link to comment Share on other sites More sharing options...
Bham Posted January 27, 2021 Report Share Posted January 27, 2021 You could possibly be not shrinking enough but I'm gonna go with the second half of Smookee's comment, and say it's the way you are installing the piece. It sound like you are squeegeeing it down wrong and creating the fingers. Link to comment Share on other sites More sharing options...
clear solutions Posted January 29, 2021 Report Share Posted January 29, 2021 On 1/27/2021 at 5:23 AM, smookee408@yahoo.com said: Two possibilities. Its not shrunk enough. Once you’re done lift the film again and do a final shrink down. Two its the way you squeegee and you’re creating the fingers. This.. Link to comment Share on other sites More sharing options...
Booms Posted January 29, 2021 Report Share Posted January 29, 2021 As stated above, fingers are caused by under shrinking or improper squeegee technique. All a finger is, is excess film OR tension where it shouldn't be...or a combination of both. Next time your doing a back window, pay attention to what you are doing when the finger appears. And stop doing the "+" pattern on your squeegee technique. You are causing yourself problems with that. Question...for finishing the bottom of the film, how do you squeegee? Be specific. You're welcome. TintDude 1 Link to comment Share on other sites More sharing options...
Tint Eastwood Posted January 30, 2021 Report Share Posted January 30, 2021 Try doing a wet check when you’re done shrinking. That should highlight any areas that you are not shrinking enough. Tint Slayer and TintDude 2 Link to comment Share on other sites More sharing options...
Tint Slayer Posted February 1, 2021 Report Share Posted February 1, 2021 i shrink beyond the future cut edge as much as possible and do a wet check every time, those fingers would show in a wet check unless its how you're push/pulling the film during install Link to comment Share on other sites More sharing options...
