2021 Polestar 2
goodtohave
Been lurking here a long time but have never posted....
Just did the new Polestar 2.  Very easy car.  I don’t pull panels, the bottom trim  is not tight, sides have lots of room but are a but deep.  No quarter windows which is always a bonus.
Back window brake light is not covered, lots of room, has little curve and is a hatchback.
Weird part was waking up the car to make the power windows work.  Like a Tesla no start button, you just need the key fob in the car, sit on the drivers seat and it powers up.  But when you get out after a few seconds it shuts down.  After some experimenting I found if you open the door, sit down and then while the door is open latch the drivers door so it thinks it is shut.  Then push the brake and shift it in and out of drive and hit park.  With the door left latched it keeps the car awake  and I was able to tint all the windows.  I also latched all the other doors shut while open.
Did one of those today. Easiest door panel I've ever pulled. Two 7mm and two t-20's. Bump the panel upwards from the bottom. The seals are kind of wide so was easier for me to top load all at once.
Behind the rubber stopper at the release handle is the top 7mm.20220609_112803.jpg.65b8cf2452ac55bced5795eac7c9fade.jpg
T20s are exposed below the armrest. The last 7mm is exposed at the bottom of the panel.20220609_112610.jpg.3e1a99f5b3bb0c58fea946a6e6778592.jpg20220609_112633.jpg.42d477da11827899af8df33e7644f0e8.jpg
Also if you hold down the start button after shutting it off an option comes on to stay powered up.20220609_093816.jpg.decc7220e3c089d4ec4a070244ecab7d.jpg
The window switches look rather euro so I would keep them dry at all cost.
      Contravision
    2. 29
    4. 3
    6. 4
    7. 3
    8. 4
    9. 3
      New tint. Not happy
    10. 3
