Rear Window/Windshield Trouble
I tinted a Accord yesterday and the install went prettu damn good for my first time and passable for a decent job.
The trouble I had was on install. I use the same slip I use on the side windows. My film will start sliding down after intial squeegee if that tells you how much slip ratio I use.
Shrinking went well and I reverwe rolled it. But on install after unrolling on the inside. You had to unroll to tuck on down at the bottom. That film jammed in place. I had to pull and yank of course adding debris and creases to the mix. I sprayed more slip and still did not help. What did I do wrong. Why couldnt I slide it at all.
Im not too hard on myself as Ive been doing trucks and front roll ups for the last year. This was my very first back window install. Evem with the problems. I ended up with just a few creases at the bottom area that I chizled almost all the way out.
Accords are a fairly easy back window to do as far as curve and shrinking is involved. Just curious why this happened.
