Where to get a Squeegee handle?
Sorry :sorry But they don't really make a handle for that style of squeegee. They make a little plastic piece of PVC pipe cut to fit that channel and slide on it, but that piece sucks and is pretty much useless.  Those are designed to be used with the hands, hence the reason the side you hold is so large(unlike a blade squeegee).
The Blue Max - Red line extractor and other blade style squeegees are the ones that have handles to fit them.
Edited by Bham
I've used the squeegee handle linked below.
You have to back the screws out as far as they can go to mount the that type blade, then tighten back real good so the teeth bite into the blade material. Not the best when it comes to sustained force so other options such as Blue Max blades would serve better.
https://www.officedepot.com/a/products/9017909/Unger-Pro-Stainless-Steel-Squeegee-Handle/?utm_source=google&utm_medium=sag
