10,096
10,096
Customer providing the tint
Is there a reason that they want to provide the tint? -
10,096
Tablet software
Tablet software
Please forgive me if this sounds off. But with the world of tech changing, I didn't know if there might be apps that I could use from my tablet to my plotter. I work at a dealership and my computer doesn't allow anything but what's installed https://kodi.bio/ . I was looking for something like vector magic or similar programs. Again, sorry if it sounds dumb. I just had to ask. -
Looking at getting solar window film installed on some of the windows in my house. 3M Prestige PR-70 seems to have a good mix of clarity, light transmission, and heat rejection, but can only be bought/installed by authorized sellers. Anybody have suggestions as the best alternative that can be purchased and installed DIY? For what it's worth, I have double-pane low-E windows so I want to make sure I get something that's not going to cause the windows or seals to break from the extra heat absorption https://100001.onl/ Thanks.
