Cooltimes Posted April 8, 2022 Report Share Posted April 8, 2022 (edited) Customer states that the gps is no longer working after tinting his car. He also said his car will not connect to his home wifi. We did not tint the windshield. So wondering whats up or maybe the problem was already there and just happened the day after we tinted his car. Does anyone have info. I have never had this happen, the car is also out of warranty for this. Also the wifi antenna is located in the mirrors. So I don't understand how that happened as well. I guess I just wait and see the outcome. I talked to another shop that has done hundreds of these car and he's never had it happen to him. I guess the only way to make sure your not buying some ones pre existing or intermintet problem is, i guess verify everything works before the car is tinted. I let you guys know the outcome. Edited April 8, 2022 by Cooltimes more info Link to comment Share on other sites More sharing options...
Dano Posted April 9, 2022 Report Share Posted April 9, 2022 I always get a signed waiver up front before working on those and just about anything thats Euro or electric. I would check the tesla forums. Also look for a technical service bulletin (TSB) that may have been issued. NHSTA may have some complaints registered as well. Good luck. Link to comment Share on other sites More sharing options...
Tintguy1980 Posted April 9, 2022 Report Share Posted April 9, 2022 (edited) Here's a couple of possibilities, but they should be considered presumptive reaching: WIFI antenna in side mirrors may have receiver/connections in the door that could get wet? Stretch, since moisture from rain could intrude; engineers should/would design around this possibility. GPS receiver/antenna under rear dash (in trunk)? Moisture intrusion when rear window film was installed? Hmm, don't see this much these days (see ending sentence). Heavy metalized window film installed with GPS antenna under rear dash? NOT!? Heavy metalized window film for auto has been extinct for years. It would be helpful for defense purposes to know where the critical components of the two systems are located. If not in harms way of install solutions, then I'd call 'BS'. Edited April 9, 2022 by Tintguy1980 Won't connect with home WiFi? What the H; is his car another room in the house? Link to comment Share on other sites More sharing options...
Cooltimes Posted May 25, 2022 Author Report Share Posted May 25, 2022 Never heard back from customer, must of worked itself out. He just bought this used and must of fixed it self after a complete reboot of software and down load. Just be careful in the future and have them sign something. Otherwise you could be buying someones pre existing problem. Link to comment Share on other sites More sharing options...
