Should 5% auto tint be a two person job?
If you are getting debris visible from the outside while installing something is wrong. Perhaps better lighting in the shop because you can usually tell right away unless it's very small. Plus since there is some degree of contamination in every job, it should be inspected and any dust pressed down to make it invisible before it leaves the shop. -
Hi. I was wondering if 5% tint on a car should be a two person job because it is so hard to see imperfections from the inside when applying dark tint like 5%. Should there be an applicator on the inside and an outside spotter to see the imperfections as it is applied? -
Anything wrong with replacement?
I've had old tint removed and the windows retinted with no problems a couple of times in the past. They can scrub the glass and get it clean. This is where an good installer is key. -
10,085
The Off Topic Thread
Morning ever E body. Brutal cold this morning. We got seasoned with pollen and thrown back into the fridge to marinate. We are gonna COOK this summer. -
I had xpel xr+ installed and noted a defect in the tint (looked like a pencil eraser sized rough area) and shop said they would remove and replace. I’m wondering if the removal and replacement is going to lead to a worse end result (e.g. left over residue from first tint) and I should just live with the defect. Thoughts? -
10,085
Even though it’s almost freezing outside, still getting stuff ready for the tunnel and open planting. -
HELP.. Looking to recreate German factory green glass look
I haven't seen it myself, but in my quest to choose ceramic tint for my new car I have read some complaints that Solar Control Ceramikool tint has a bit of a green color to it. I am not certain how common it is where you are located. I know if a shop in the Houston area that installs it. -
10
3M Crystalline for 499 for a RAV4? Houston shop
Thanks. Good info. This is the type of info I was looking for in my thread. I have a gray Mercedes GLS with factory privacy glass so I really want the tint to be gray/black rather than geenish, brownish, etc. I am supposed to go a by a couple of the shops I have talked to this week and look at samples in person of what they want to install so hopefully that will help.
