finally doing e46 3 need help?!!
Guest newtinter
Guest newtinter
Ok so I am finally doing the 330ci I was supposed to do a long time ago and I am having a hell of a time with that rear window. I have heat shrunk a number of cars already and this one doesnt look so hard but for some reason I keep creasing the film and when I managed not to crease it pealed away from the bottom of the window and I had to remove it. Are there any secrets I should know about these windows? are relief cuts needed and if so where? Please help im quite frustrated!!haha
Guest naughtydog
sounds to me the reason it's peeling away is because you've over-shrank it. I do this every now and again.
Try just shrinking the fingers and then wet check it
Are you powder/wet shrinking?
Naughtydog
Guest naughtydog
cut the film out and then wet check it, give it a final blow over with the heat gun to laydown any little fingers and tighten the shrink and then skin the film to the glass. Make sure the bottom edge is as tight as it can be. It should lay down Ok then
Naughtydog
      Customer providing the tint
    2. 1
      Tablet software
      Tablet software
    4. 1
    5. 6
    6. 1
    7. 6
    8. 6
    9. 28
    10. 6
