Summa S2 D160 64" Vinyl Cutter Plotter
Designed specifically for high-volume vinyl and digital print shop environments, Summa S Class cutters have a long-established reputation for reliability, innovation and outstanding performance – all with tracking accuracy that is second to none. When tight deadlines loom and your jobs require hassle-free, perfect cuts, the S2 D Series truly shines.
MODELSumma S2 D160
CUT TYPEDrag knife with TurboCut and Tangential Emulation Modes
CUT WIDTHS62.2-inch (158 cm), Extended Mode: width of the material
CUT SPEEDAll S2 models cut at speeds up to 56 inches (1414 mm) per second diagonal
AXIAL ACCELERATIONUp to 4G
MAXIMUM ACCELERATIONUp to 5.5 G diagonal
REPEATABILITYWithin ± 0.004 in. (0.1 mm) on plots up to 40 ft. (12 m) long
TRACKING164 ft. (50 m) long
CUT FORCE0-400 grams of down-force, in 5 gram increments
DISPLAY LANGUAGESEnglish; French; German; Dutch; Italian; Spanish; Polish; Czech; Latvian; Portuguese
CONNECTIVITYUSB; Ethernet
POWER REQUIREMENTSAC 100V to 240V ±10% 48-62Hz, 85 VA maximum
DIMENSIONS88.6 (W) x 26.8 (D) x 43.7 (H) in. 225 (W) x 68 (D) x 111 (H) cm
SHIPPING WEIGHT251 lbs (114 kg)
OPERATING TEMPERATURE59˚ to 95˚F (15˚ to 35˚C)
STANDARD ACCESSORIESWinPlot or MacSign Cut Software, CutterControl Parameter Software, CD w/ Manuals and Drivers, Quick Start Guide, Power Cable, USB Cable, Media Guide Flanges (set of 2), 1 Spare Fuse, Standard 36˚ Blade Holder, 2 Standard 36˚ Blades, Cut-off Knife (Manual Slitter), 2 Cut-off Razor Blades, Pouncing Pin and Holder, Stand and Basket.
OPTIONAL ACCESSORIESMotorized Take-Up Roller, Media Rack
Asking : $2950
contact for pictures
Email: tkara@protonmail dot com
(530) 276-8578
