Check out the Member Map
This shows push pins for members placed on a map so you can see where everyone is at a glace. If you hover over a pin, it will give you member info etc. The link to it is on the front page of the forum on the upper right labeled "Member Map".
When you first open the page. the US map is displayed, just chose Europe from the pulldown menu, then click "Put your pin on the map." on the lower left, then click the map on your location. :shock
http://www.tintdude.com/forum/index.php?act=membermap
:evileye
Guest expertint
Hey TD I clicked on what looked like SD and got Reid.Can you put me on just So. of that Yankee??? San Diego,by the border.Si.
