Double Barrel
Guest djtekk707
Guest djtekk707
Hey everyone im about to start using two heat guns. Can anyone tell me what to watch-out for and how to position the two heat guns. Thank You pics would be helpful. :bdog
Guest Old Dude
Recently started using 2 myself using the soap method and don't know how I ever shrunk without it. I hold them with my index finger in between the handles but have been meaning to find one of those thin flexible coozzies to strap across them. Never tried 2 on any single ply film, just 2 ply. Turn em wide open and keep them moving over a 1/4 section of a window at a time shrinking from anchor line to top or bottom. If it's a glass that is taking quite a bit of time to do a section then leave that side to go to the other let it cool and then come back to it. I do one side of the bottom then the other and then I start the top. I like to use a white teflon card to smooth as I shrink although at more fingered areas I use my hand to smooth as I shrink then hit again with heat and card. Best method ever and very easy to learn with a little practice. My first car using this method was a '02 Vette. Nailed it 2nd try :lol
Guest Old Dude
I think you may find it easier than you think. It'll help big time if you're used to the soap method. If not check out M-Dogs soap method on the site. He originated it but I don't know if he was using dual guns at the time. By the way, shrink from center out to the side.
    4. 7
    6. 11
