TintWizard Posted March 14, 2008 Report Share Posted March 14, 2008 Now that I got your attention, I've never promoted tint as a gas saver because it never really saved you enough money in gas savings by making your A/C run a bit easier to really make it a selling feature. Until now??? Gas is going to get Sooooo expensive , I wonder if it's worth looking into to figure out how much money the average driver would save when using his A/C after so many hundreds of hrs of use Thoughts ? Link to comment Share on other sites More sharing options...
TintWizard Posted March 14, 2008 Author Report Share Posted March 14, 2008 When you think of it..by the time summer is here..gas could be as much as 3 times what it used to be 10 yrs ago...which means whatever money you DID save on the A/C consumpion part of the fuel..it's going to be 3X the savings ...whatever it was..yet tint jobs still cost the same (seperate arguement..we'll stay focused on this ) See where I'm going with this ? Is it going to now be possible to use it to a tinters advantage as a selling tool ? Just trying to put a positive spin on the rising cost of fuel..perhaps I'm grasping at straws..but no doubt about it..if the tint stops a certain amount of heat coming in a car, the A/C isn't working as hard, therefore not consuming as much gasoline..but what's the percentage..2% ..4% ? Link to comment Share on other sites More sharing options...
justn8 Posted March 14, 2008 Report Share Posted March 14, 2008 I wonder if it would even be comparable to the amount you save by using your A/C at highway speeds instead of having the windows down... and vice versa in town. I'd guess it would be less than that but it has to be measurable... Link to comment Share on other sites More sharing options...
Guest darkdan Posted March 14, 2008 Report Share Posted March 14, 2008 Gila says so on the box. You have to look at it this way. Even in a mild climate there are very few days that window tint will make it so you can turn OFF your A/C and have the same comfort. Turning it down doesn't do anything. It has to be OFF. Also, keep in mind A/C on when at speeds above 45 or so gives you better gas mileage. Well, speeds above 45 mph are also the speed that gives you decent air flow through the car so you're not hot! So the only time window film will increase gas mileage are the few days that you're going less than 45 mph and the tint provides a level of comfort to turn off the A/C compared to it being too hot without the tint. I've spent years trying to improve my gas mileage. www.auto-rx.com has been the number one way to improve it on any vehicle with significant miles. Link to comment Share on other sites More sharing options...
TintWizard Posted March 15, 2008 Author Report Share Posted March 15, 2008 If Gila says it on the box..then it MUST be true Link to comment Share on other sites More sharing options...
justn8 Posted March 15, 2008 Report Share Posted March 15, 2008 Gila says so on the box.You have to look at it this way. Even in a mild climate there are very few days that window tint will make it so you can turn OFF your A/C and have the same comfort. Turning it down doesn't do anything. It has to be OFF. Also, keep in mind A/C on when at speeds above 45 or so gives you better gas mileage. Well, speeds above 45 mph are also the speed that gives you decent air flow through the car so you're not hot! So the only time window film will increase gas mileage are the few days that you're going less than 45 mph and the tint provides a level of comfort to turn off the A/C compared to it being too hot without the tint. I've spent years trying to improve my gas mileage. www.auto-rx.com has been the number one way to improve it on any vehicle with significant miles. Good point... on any fan setting I guess the compressor kicks in as often as it needs to... ? Maybe only with automatic climate control it would make a difference... if anything... at all... Link to comment Share on other sites More sharing options...
Guest darkdan Posted March 15, 2008 Report Share Posted March 15, 2008 I don't know about yours, but on my cars ANY fan setting makes it kick in. Even while it's on heat it runs (to keep the seals from going bad in the winter). Link to comment Share on other sites More sharing options...
Guest 1PEECBARETTA Posted March 15, 2008 Report Share Posted March 15, 2008 The cars with thermostatic controls will benefit the most, yes dan you are right . cheap and old cars like ours , the a/c compressor comes on anytime the a/c is on. Link to comment Share on other sites More sharing options...
Guest Kokomo Tint & Dent Posted April 29, 2008 Report Share Posted April 29, 2008 sounds like a job for Mythbusters. I love that show Link to comment Share on other sites More sharing options...
Mr paladin Posted April 30, 2008 Report Share Posted April 30, 2008 sounds like a job for Mythbusters. I love that show I actually emailed myth busters about this topic about a year ago maybe if enough people email them about it they will do it Link to comment Share on other sites More sharing options...
