flat glass
This for for when you need to know what piece you cut for your top, so that you can slide it behind the locks. I am assuming here that you all put a piece of tape on the rolled up film after you cut it. What you do is put the tape in two differnt directions. For example, the top piece gets a vertical piece of tape, where the bottom piece gets a horizontal piece, or vice versa. This way all you have to do is look at the tape and no more wondering, or going out of your way to seperate them!
Also if you have the factory edge on one of the sides. Simply put the tape closer to the factory edge side, and agian just look at the tape and know instantly what side has the edge.
    2. 7
    6. 11
    7. 11
