Wax technique
Instead of using baby powder, use wax. I use some "shaping spray" from my distributor. Enprodistributing.com.
Spray it on, or if not in a can, wipe a small amount on the back glass. Let haze up a little. Do your "H" with a damp paper towel to anchor the film and shape from the middle up/down. You can hold a heat gun on the film for a long time with wax before it starts to burn the film.
Anyone else do em this way? At least for more curved back glass's??
Guest Texstar
A new one to me but sounds well worth a try. thanks guys :dunno
Its basically the same as the slip solution spray on and soap method. The wax just drys to a light haze and give the film the float. Good luck :spit
