skanlan Posted May 1, 2006 Report Share Posted May 1, 2006 Some like using the vertical glass for cutting patterns some use the car itself!! Here's another way if you use the car!! Instead of cutting your pattern then shifting the corners towards the glass to round off!! Just keep it in place and slide a 4 x 6 self healing cutting mat under each corner then trim off!! It even has lines on it you can follow for a straight edge!! Fits in your back pocket out of the way from other tools in the pouch!! Good for the mobile jobs if your at a car dealer,Beats carrying a 60 x 40 glass around!! You can get any store like Fred meyers,Wally,Target etc..arts and craft section X-acto also sells one with the knife and blades!! Link to comment Share on other sites More sharing options...
Guest zolar Posted May 1, 2006 Report Share Posted May 1, 2006 Some like using the vertical glass for cutting patterns some use the car itself!!Here's another way if you use the car!! Instead of cutting your pattern then shifting the corners towards the glass to round off!! Just keep it in place and slide a 4 x 6 self healing cutting mat under each corner then trim off!! It even has lines on it you can follow for a straight edge!! Fits in your back pocket out of the way from other tools in the pouch!! Good for the mobile jobs if your at a car dealer,Beats carrying a 60 x 40 glass around!! You can get any store like Fred meyers,Wally,Target etc..arts and craft section X-acto also sells one with the knife and blades!! [*]394942 those things work great for vinyl too Link to comment Share on other sites More sharing options...
skanlan Posted May 2, 2006 Author Report Share Posted May 2, 2006 My bad I said no shifting. with the front you can fold back onto the mat then trim when it's hard to reach behind the mirror!! front of pattern facing trunk!! Don't crease when fold DUHH!! Link to comment Share on other sites More sharing options...
