Guest darkdan Posted August 25, 2006 Report Share Posted August 25, 2006 Does the 06 coupe accord need felt or is it just the sedan? Link to comment Share on other sites More sharing options...
Guest ninjatinter Posted August 25, 2006 Report Share Posted August 25, 2006 05 needs it, so I'd say yes. Or atleast prepare the customer. Link to comment Share on other sites More sharing options...
Guest darkdan Posted August 25, 2006 Report Share Posted August 25, 2006 That's cool. I thought it did, but then was second guessing myself. Link to comment Share on other sites More sharing options...
Guest ninjatinter Posted August 26, 2006 Report Share Posted August 26, 2006 I forgot about it and got boned on the last 05, thats how I remembered!! Link to comment Share on other sites More sharing options...
Guest darkdan Posted August 29, 2006 Report Share Posted August 29, 2006 Turns out it was an 05 and not an 06, but the 05 coupe did indeed need it. Panel removal wasn't too bad. The first one didn't go so well, but the second one was easy. I removed the two screws behind the door handle. I removed two below the handle. I took off that triangle by the mirror. Then I popped the tabs on the bottom (did you know there's a little circular mark molded into the door telling you there's a hidden tab above it?). A little bit of a lift. Then I unplugged the wiring harness for the locks/windows and undid the bulb. I undid the 7 screws or whatever holding on the door handle to the panel. After I got the panel off I could get the locks/windows plate off! Stupid thing was on there so tightly I couldn't remove it before hand. The driver's side came off after I put a little pressure next to it to give me some room. Link to comment Share on other sites More sharing options...
