Guest rookeytinter1 Posted January 16, 2007 Report Share Posted January 16, 2007 can anyone please tell me how to remove the front door panels on a MAZda milenia 01' 0? I removed a srew towards the bottm front and still won't budge. removed the rear d/p easy but the front ones seem too still have a screw holding it.would greatly apprieciate any good advice on these D/P oro trick for all door panels in general? thanks Link to comment Share on other sites More sharing options...
micro-edge Posted January 16, 2007 Report Share Posted January 16, 2007 The gaskets tuck really easy. tuck em and popem up after tinting. Link to comment Share on other sites More sharing options...
Guest tintgod Posted January 16, 2007 Report Share Posted January 16, 2007 can anyone please tell me how to remove the front door panels on a MAZda milenia 01' 0? I removed a srew towards the bottm front and still won't budge. removed the rear d/p easy but the front ones seem too still have a screw holding it.would greatly apprieciate any good advice on these D/P oro trick for all door panels in general? thanks there is no screw...there is a metal pop/clip right at the handle area behind the door panel..try lifting up on the panel and it will slide off ..or if you want to take a chance..pull like a mother f'er and it will pop off.but yor best bet is to slide it up off .good luck Link to comment Share on other sites More sharing options...
VIP tint + glass Posted January 17, 2007 Report Share Posted January 17, 2007 thats exactly right. then you can either try to slide it down to get it to realign or use a screwdriver to pop the clip out and put it back onto the panel. then you can just slap it straight in. Link to comment Share on other sites More sharing options...
Guest tintgod Posted January 17, 2007 Report Share Posted January 17, 2007 thats exactly right. then you can either try to slide it down to get it to realign or use a screwdriver to pop the clip out and put it back onto the panel. then you can just slap it straight in. yeah..its easier just to take the metal pop off the door panel and slide it back on the inside door skin and just pop the panel back on Link to comment Share on other sites More sharing options...
pike_madcat Posted January 17, 2007 Report Share Posted January 17, 2007 there is no screw...there is a metal pop/clip right at the handle area behind the door panel..try lifting up on the panel and it will slide off ..or if you want to take a chance..pull like a mother f'er and it will pop off.but yor best bet is to slide it up off .good luck Link to comment Share on other sites More sharing options...
Guest tintgod Posted January 17, 2007 Report Share Posted January 17, 2007 Link to comment Share on other sites More sharing options...
Guest rookeytinter1 Posted January 24, 2007 Report Share Posted January 24, 2007 thanks I got it 1st. I tryed ,The gaskets tuck really easy. tuck em and popem up after tinting.method but I could'nt popem back up without tinting or with the window down, so I just took the d/p off Oh and there is 2 screw's holding them inside the lil door compartment. yeah I finally looked and surenuff but I still had 2 put the window down after tinting 2 get it back on. thk god only I got bck up wthout so thanks again peeplz . Link to comment Share on other sites More sharing options...
Guest willie Posted January 24, 2007 Report Share Posted January 24, 2007 glad we could help Link to comment Share on other sites More sharing options...
