Guest Peja43916 Posted July 18, 2010 Report Share Posted July 18, 2010 Any advice on this car? Should I pull the panels or will I be able to pull just the top part to get gasket out without taking whole panel off? Thanks in advance. Link to comment Share on other sites More sharing options...
Guest SqueegeeMaster Posted July 19, 2010 Report Share Posted July 19, 2010 we do them without removing anything - using the top to bottom method. If you cut the kit close enough on the sides then you don't get creases... if for some reason you feel you have to pull the trim, I think there is just one torx screw under the door handle and one under the lever... but I can't be sure cos I never take them apart... usually tint the whole car in about an hour and ten mins they're one of my faves Link to comment Share on other sites More sharing options...
Guest Peja43916 Posted July 20, 2010 Report Share Posted July 20, 2010 we do them without removing anything - using the top to bottom method. What is the top to bottom method? Link to comment Share on other sites More sharing options...
Guest tint325i Posted July 20, 2010 Report Share Posted July 20, 2010 pull the panel, it takes about 30secs to remove it, same as e90 3 series Link to comment Share on other sites More sharing options...
