Guest FAST TINT MAN Posted August 4, 2010 Report Share Posted August 4, 2010 We do a lot of hondas do not remove the deck just do it old school use a clip board problem solved..and after doing that car just buy yourself a bulldozer is worth the money! Link to comment Share on other sites More sharing options...
SuperSetKing Posted August 4, 2010 Report Share Posted August 4, 2010 a tail fin should also work along with swiper or stroke dr. bingus!! Link to comment Share on other sites More sharing options...
NvrLate Posted June 5, 2013 Report Share Posted June 5, 2013 Bingo to what everyone says, don't do it. I did it once and tried a second and wont do it again. I'm a deck puller when they are in the way and easy, but these suck. There is one metal/ green plastic clip on each side that simply hates to be popped loose and is hidden by the air bag. And, once you do get it loose, (both sides) the deck is bigger than the car, hard to line up, the reinstall of the side pillars will fight you, by the time you r&r you could have messed up 2 pieces of film and tinted it 3 times. Bulldozer and just lay it in. The only exception that would make it worth it is a strip and retint if its behind the brake light, but I would quote an hour labor for the rear deck alone. Link to comment Share on other sites More sharing options...
