Bpdebroy88 Posted October 20, 2016 Report Share Posted October 20, 2016 We actually spray the side mirror and underneath before peeling the film (if u peel off rhe car). Hopefully to keep dust and dirt from falling onto the pattern. Also spray the film and all around the door to get rid of static thats on the film. Little stuff that makes a big difference. High pressure light mist on the film so that water doesnt run into the pattern and bring dirt. When installing back corner first, drop the front down until u have enough room to slide the front in. We actually spray down on the front edge before final squeege to wash away any dirt. Get very very clean outcomes and never pull panels. Link to comment Share on other sites More sharing options...
shadytints Posted November 2, 2016 Report Share Posted November 2, 2016 front edge specs can be eliminated by using a kaywos, or perfect cloth. wipe top of glass, wrap cloth over ez reach and wipe into gaskets. spray top of glass top 4 inches into front where you cant wipe, then final squeegee then ez reach into front and rear to remove any water. light mist and apply . the water on the top of glass runs down front edge when applying into front gasket and can leave dirt trail or specs in front. call it the gravity issue. the top of glass is dirty especially laminates and you cant wipe top in the gasket. Link to comment Share on other sites More sharing options...
