1998 Ford E350
Guest FilmBlazer
Guest FilmBlazer
I need to bid one of these... I know its old, and I want to bid accordingly, anything to look out for? Will 22" film cover the glass? It looks like 24" might be required. Any input is appreciated :ninja
Guest banfam55
The van????
BETWEEN 3-600..Pending the job and film spacifics.. :ninja Alota work brotha and materials..
1998 E350 van?Well IF its the same as a 2000-the fronts are 22.65" tall.If its the old style with wing vent windows they are 20.19" tall.The computer skips from1991 to 2000. My guess would be the same as 2000. :ninja
22 will fit if you hold your tongue just right :ninja
Pull the film 40-42 instead of 36 and pull the bottom corner way down to cut the bottom.
It will not go under the seal though if you do it this way
If you have 24 use it :ninja
Good luck :ninja
Good luck :ninja
22 will work if you want a 3/4 inch gap at the top...like willie does.WTF? :ninja
Guest willie
22 will work if you want a 3/4 inch gap at the top...like willie does.WTF? :eyebrows
E350 Super Duty trucks have the same window as the F250
if its a truck 22" fits if pulled right
Have no clue if its a van but the question doesnt mention van :shock
Guest haroldshouseoftint
Have no clue if its a van but the question doesnt mention van :eyebrows
F series are trucks, E series are vans :shock:shock
my bad .....but 22inch will fit f series
Shouldnt you be attending the Raven Jersey bonfire this morning :shock
:eyebrows:shock Not if I'll be walking you through types of trucks/vans :DD:DD
    2. 1
    3. 7
    5. 7
    6. 1
    7. 7
    8. 7
    9. 0
    10. 7
